AIO buying advice?
frozensun
Guys when you look at for the best AIO cooler out of the market,what do you look at for?
Seems to me from what I hear Corsair is the most expensive but cooling performance mediocre.
How about Thermaltake,deepcool,coolermaster ML etc...
Do you look at the pump type and which is the best,do you look at the fans specs (low,high static pressure what else?),do you look at the radiator size,what?
In case I want to buy other AIO for my 3900X,out of like 200 AIOs I really can't decide since I don't know what to look at for.
Please no air coolers this time,in regards to their good performance,I'm kinda bored to now look for one since my RAM is quite tall,and air coolers yes they do the job but they are boring to me.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
2 minutes ago, frozensun said:
In order of importance,
- Serviceability (e.g. Alphacool Eisbaer LT solo), leaves options for customization
- Radiator size/thickness
- Pump/Block OEM (e.g. Asetek, Coolit, EKWB, etc etc)
- Fans are not important to me, as I will most probably replace them with Noctua A12x25, so in fact, cheaper fans the better in my perspective
- Warranty
At the end of the day, an AIO is an AIO, its targeted to a certain audience. An AIOs value in pulling the illusion that you are getting into watercooling and performance of a watercooler.
I used Gamers Nexus graphs to show which AIO's perform well, since the pumps are almost all the same.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Could you link it plz?
I suppose Freezer II is the best out there,and best budget AIO.
- Warranty
ok.
So longer radiator better dissipates hit or thicker?
280 mm vs 360mm.
Which pump is better in a order asetek or coolit or if there are any other.
10 hours ago, frozensun said:
ok.
280 mm vs 360mm.
360 is marginally better than 280, but 120 mm fans are generally more static pressure optimized so they will perform a bit more efficiently. I like Asetek, but Coolit is also fine, though I like EKWB more. <removed by staff>
Edited by SansVarnic
Removed content.
I can't find the one I used, but I was watching their videos and then they compare the one they're reviewing with the others...  see 7:50 for an example.
https://www.gamersnexus.net/hwreviews/3499-evga-clc-360-liquid-cooler-review-noise-normalized-thermals
OnePlus:
Other Tech:
