Just wondering how my first pc setup stands up. I am a first time builder just getting into pc gaming of my own.
Thanks for any comments or feedback! would love to hear what you guys think
Parts list:
 Intel Core i5-10400F
 GeForce® GTX 1660 SUPER 6GB
500GB WD Blue SN550 Series PCIe NVMe M.2 SSD
 1TB WD Blue Series SATA-III 6 GB/s SSD
16GB (8GBx2) DDR4/3000MHz
GIGABYTE Z590 UD AC ATX
EVGA 600Watts 80 Plus Gold
https://linustechtips.com/topic/1313154-rate-my-first-build/
Looks good. If you are very picky on how fast a game loads from your HDD, make sure that your HDD has a RPM of 7200, not 5400.
Having an HDD with 5400RPM will make games load very long, so do make sure that the HDD you're getting has a speed of 7200RPM.
→  Kindly quote or mention me if you would like a reply back.
<famous quote>
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542411
Prebuilt?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542418
Was looking at SSD rather than HDD for game storage. Would i still have the longer loading times with the SATA-III SSD mentioned?
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542434
Oh my bad, I read that wrong, I thought it was an HDD.
Load times will be significantly faster if you use SSDs compared to HDDs. So no, you will not have ridiculous long load times.
<famous quote>
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542437
Just now, Executivz said:
I also went with a modest CyberPowerPC MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with Dual Chamber Pump. Hopefully I shouldn't have any issues with cooling with a single fan radiator?
Those are generally not much better than a decent air cooler, with a far greater chance of failure.
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542443
If your liquid cooler only has one fan, then I see no point in getting it. You can get an air cooler and it'll perform as well as the single fan liquid cooler.
If you can increase your budget, a double fan liquid cooler like an NZXT Kraken X53 or a Corsair iCUE H100i RGB PRO XT would be ideal.
<famous quote>
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542453
Far greater chance of failure as in while operating?
You have more points of failure compared to a tower air cooler, like the pump, etc for not really much gain.
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542459
If you care how fast your games load, or how fast your system is in general, you get an ssd, hdd's are pretty obsolete except for mass and long term storage
3 minutes ago, c00face said:
If you're not overclocking, no point for the z motherboards as youre just spending more money for nothing
the cpu is a 10400-f so he won't be doing any overclocking, but having a good motherboard leaves a path for upgrade.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542472
2 minutes ago, c00face said:
upgrade to what exactly? hes not overclocking.
what I mean is the CPU is not a K sku, he won't be able to overclock no matter the motherboard. What I'm saying is having a good z490 motherboard leaves an opening to get a better 10700k or 10900k in the future for cheap, sure you don't need a Z490 board to upgrade to those cpu's, but what's the point if you don't.
AMD blackout rig
https://linustechtips.com/topic/1313154-rate-my-first-build/#findComment-14542488
