Help With Cpus
Solved by SupaKomputa,
It's okay, if you're fine with the AMD be more expensive go ahead, or just buy that intel if you think it's not a problem.
x570 is definitely superior, but that doesn't mean B550 is a bad choice.
_Darasuum_ ·
Posted in Power Supplies2 -
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting4 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3
play_circle_filled
Latest From ShortCircuit:
