I currently own an arctis pro (wired)  & a sennheiser hd600 both have failed to give me surround sound audio, I've tried disabling windows enhancements in windows properties settings, I've tried plugging them into different ports, using an amplifier etc like people suggest and it still isn't working & my audio is just flat, I've also tried listening to YouTube videos that test your headphones for 7.1 surround sound and again there is no directional audio on either of the headsets. I'm looking to get a pair that actually works so I can properly hear footsteps etc. I'm currently looking at audeze mobius & hyperx orbit s. I'm just wondering if they are any good, I really don't want to spend any more money until I know for sure if they're going to actually work as intended.
Edit: I fixed it, there's a setting in sounds that I didn't even know was enabled called "mono audio",  not sure why anyone would want this.
https://linustechtips.com/topic/1310491-best-headset-for-footsteps/
If you want true 7.1 surround you are going to be shelling out for a 7.1 surround speaker setup, which is ridiculous...how sweaty do you have to be at some games to have already spent hundreds on headphones and still want to spend more just to hear some footsteps? lol
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
The Logitech G933 Artemis is awesome. It features 7.1 surround sound and works like a charm.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
It also weighs so much that it'll give you headaches after half an hour... (at least in my experience, used it for 3 years).
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Am using it for about a year now and am wearing it quite often for 8 hours + without any complaints.
OS: Windows 10 Pro
OS: Kali Linux
It's not JUST footsteps, that's just an example I'm giving.
My point still stands lmao it's stupid to be spending any more money on audio gear.
SPECS:
