ok i have a problem i am getting two gtx 465 and am going to start folding with them but the motherboard i am installing them in is a socket 775 asus p5n-e sli its a pci express x16 1.0 motherboard but if you populate both the pci e slots it drops to 8x speed  my question is will there be a noticeable drop in ppd with the limited speed.
https://linustechtips.com/topic/13102-pci-e-lanes-and-folding/
Well my knowledge might be a bit dated (so take what I say with some salt until someone else can confirm themselves) but PCI-e bandwidth "shouldn't" affect F@H performance last i checked.
http://www.evga.com/forums/tm.aspx?m=1752040&mpage=1&print=true
So even running if your running x1 speed, you should be fine.
https://linustechtips.com/topic/13102-pci-e-lanes-and-folding/#findComment-139879
Warmon is correct - the lane bandwidth does not matter - have have cards hooked up to x1 slots via x1 to x16 expanders and they fold fine. You won't have any issues...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/13102-pci-e-lanes-and-folding/#findComment-139918
