MSI Dragon Center(Mystic Light) causes skipping with G Skill Trident Z RGB
When I first built my computer the Ram would cycle through colors forever but I wanted to try and customize the RGB. I downloaded Dragon Center(Mystic Light) and I didn't like the options so I put the Ram on the 'default' setting. But now it skips colors every few seconds. How can I fix this?
(Skips from blue straight into pink)
  • 2 months later...
11 hours ago, Sir_Autismus_ said:
Do you know a fix by now? I have the same problem
No I've asked on a few different sites and forums but no one responds because I assume they don't know how to fix it either.
  • 4 weeks later...
Hey, so I've been having this issue too. Seems like I still had MSI stuff still installed. Deleted MSI Mystic Light and Dragon one center, if I remember what that's called. All file locations should be in the Program Files folder (either x86 or X64) and Program Data. Works fine so far, although I haven't restarted my computer yet. Hope that helps!
