I have an RX 580 pre oc'd from Sapphire which randomly crashes in some games. I see the shutting down with the buffer wheel and for a few seconds the computer is off but then suddenly it turns back on by itself and the GPU fans ramp up to max speed. This lasts for about 20 seconds before the PC shuts off again and when I turn it back on there's no information on why it crashed leaving me confused and scared. Can anyone help me? Has anyone else had this issue?
https://linustechtips.com/topic/1310008-issue-with-my-gpu/
Like they said before monitor the temps...sounds like the video card might be overheating...your gpu has the same safeguards as your cpu ..so if it overheats it will either underclock itself or shut off hence why your pc is shutting down....try removing it making sure it isn't clogged with dust and then reseat it making sure it's properly connected...try running the game and in the middle check the Temps...or check the Temps right after it crashes
https://linustechtips.com/topic/1310008-issue-with-my-gpu/#findComment-14517828
2 minutes ago, ISeven_WH said:
What's the best application for monitoring temps?
hwinfo
HWiNFO - Free System Information, Monitoring and Diagnostics
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1310008-issue-with-my-gpu/#findComment-14517878
