NH-D15, second fan doesn't fit.
OldTweaker
Just upgraded to a Ryzen 9 3900XT with a NH-D15. Unfortunately the second fan doesn't fit in combo with my memory.  (Asus TUF B450-PLUS GAMING mainboard).
I can add some fans to the top of the case, but it seems to me the one fan is more than sufficient and already have an exaust at the back of the case. I don't overclock. Any tips if the second fan is really required?
So you have high profile (taller memory) sticks? What exactly do you have?
Else if it doesn't fit, get the salami lid.
Or if you have space anywhere else, but yes this is a problem with big air coolers if you didn't look into before buying?
Guess I should have checked 🙂, normal height memory. Just too close to the fan
so a thinner fan would work? think one can buy one. but maybe not what you wanted.
If the case has enough clearance, you can mount the fan higher on the heatsink. Otherwise, you can just use one fan.
The fan can be repurposed elsewhere in the system.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
I'm sure you're aware of this, but just in case: the fan doesn't have to be completely aligned with the fins.  I had to offset my fans about half an inch so I would have clearance with my own RAM.  The only concern at that point is whether your case side panel will close.  Pic enclosed:
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
Thanks, for the help. I know it doesn’t have to align, but then it still doesn’t fit in the case. For now I’ll keep it as a spare. The temps still look good 🙂
So you have option to place fan to other side of the cooler, as pulling instead of pushing. Shouldn't matter for performance that much. Also, the fan can rest on top of the RAM just fine. I can understand if you have RGB RAM and you want to show it off that its not preferred. But fan shroud is plastic, RAM heatsink is aluminum.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Actually there's a plastic cover over the back plate section which is in the way for that. I'm not into RGB 🙂 . But even with the fan resting on the RAM there really is not enough space. The temps are fine though, max measured of 68 C when putting stress on all cores.
The other fan in combination with the case fans seem to do a good job.
What RAM u have?
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
To be precise:
2 x KHX3200C16D4/16GX  (2 x Kingston HyperX 16gb)
2 x CMD16GX4M2B3000C15 (2 x Corsair Dominator Platinum 8gb)
The Dominators are the ones that er too high
On 2/21/2021 at 10:07 PM, OldTweaker said:
To be precise:
Dominators aren't normal height RAM. Normal height is 35mm. Dominators are 55mm. This is why the confusion.
you can do a cable mod to attach a smaller fan
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
