What SSD to get for macOS Catalina/Big Sur?
My vote is for the Crucial MX500 for both the Mac mini and the desktop. I'm running multiple MX500s on different Macs, and they've been excellent in terms of cost, reliability and performance. Last I checked they were also cheaper than the 860 EVO. For Big Sur I'd get a larger drive. 500GB should be fine.
Also, I've heard there are some issues with the 650 Ti in macOS. Good luck with that. You really should look into getting an AMD card when the prices come back down if you're wanting to run macOS on a regular basis.
21 minutes ago, LIGISTX said:For the PC, any SSD is fine as it doesn't care. The Mac, possibly there are some that have proven to play nicer, but I am not sure. Last time I swapped an SSD into a macbook was in ~2010.
Can you run macOS on Ryzen..? There are drivers? Its hard enough to get hackintosh happy on Intel, but.... sure?
Yes, macOS runs very well on Ryzen in most cases. It was easier to install macOS Catalina on my Ryzen machine than on some Intel machines in the past.
