Hi. I wanna upgrade my pc and i'm curious because my motherboard doesn't have M.2 slot on it. I know that i can buy an adapter for it and plug it in, but i wanna use it as boot drive (Windows 10 and couple games) but idk if i will plug everything BIOS (AWARD) will pick it up with no problem. I don't wanna spend money for something that will not work.
Thx for help and sorry for my poor english it's not my 1st language spoken.
https://linustechtips.com/topic/1306548-m2-using-adapter-to-pcie/
What are the specs of the rest of your system?
5 minutes ago, pop2trony said:
CPU: AMD FX-8300 3,30Ghz
RAM: GeIL 8GB 1600MHz CL11
GPU: GeForce 1050Ti 4GB
MOTHERBOARD :Gigabyte ga-78lmt-usb3 6.0
POWER SUPPLY: Chieftec iArena Series 600W 80 Plus
and two magnetic hard drives 1st 1tb 2nd 500gb i forget the brands
Id just get a sata ssd then. That system is too old to support nvme boot, so a nvme drive in a pcie slot will work, but won't be bootable.
I would just go with a sata ssd as the speed difference is hardly noticeable between a sata ssd and a nvme drive. You would be spending alot of money just to get nvme running on an old system that wouldn't really benefit all that much from it over just getting a sata ssd and calling it good.
