Cheap airflow case fans?
Go to solution Solved by Levent,
Arctic F12/F14
Arctic F12/F14
3 minutes ago, Smegmantas said:
I need a couple fans for my new build. I have an airflow case, but I need some airflow fans. What are some dirt cheap ones, that still look decent? Please no rgb.
Arctic p12's work as well, but they're optimized for pressure, so they'd be better on rads.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
Just now, Smegmantas said:
I also have a question. How much impact do 140 fans have over 120 ones, is it even worth it? Should I just get 2 120 ones and save a few bucks?
I personally get the biggest fans I can fit because that means I can get better performance with less noise (usually).
