i only have this code in the userform
Private Sub cmdexit_Click()
    End
End Sub
Private Sub CommandButton1_Click()
    Usergfx2.Hide
    Usergfx1.Show
End Sub
http://oi58.tinypic.com/sxkhsy.jpg this pops up when i try to run or click the code to edit
this is happening to another similar slide too
btw how can i make a video play using a module?
Can you post the exact error you are getting. The entire output of your debugger or any pop up windows that appear.
hellooooooooo
https://linustechtips.com/topic/130565-visual-basic-help/#findComment-1738100
    End
End Sub
    Usergfx2.Hide
    Usergfx1.Show
End Sub
That seems like a bug with Visual Studio. Is that visual studio 11?
https://linustechtips.com/topic/130565-visual-basic-help/#findComment-1738134
