GTX 1660 Fan Curve issues
Ar558a
I have a Gigabyte GTX 1660 in my system and it's fan curve really annoys me as it engages at 50C. This means that my machine when not completely idling is usually using the GPU to watch videos or sometimes transcode the temp creeps up to 50C and then the Fan kicks in at 1400RPM for approx 30s which brings the temp down to 45C and then it gradually climbs over maybe 2-3 mins and starts all over again. It's not loud, I can only tell using OCCT but I am worried the constant cycling on and off (My machine is on 18hrs a day everyday) will kill the fan, which will likely kill the GPU and as GPU's are likely irreplaceable (Well for less than 3x MSRP from some dodgy scalper) for the rest of 2021. I dont want to run Afterburner constantly as I have enough process running using up ram as it is. IS there any way to actually adjust the nVidia Bios so I can stop this happening?
I am not sure if you can edit Turing card bioses yet. Your only option is MSI Afterburner.
Your only real option is Afterburner which really doesn't use much RAM like you seem to be worried about. Between it and RivaTuner I'm reporting about 5MB.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
