1 minute ago, Hudson Griffin said:
2nd question should I buy a M.2 drive with lower storage but with a built in Cashe or should I go higher capacity but with no Cashe
What dirves are you looking at. there is a lot more to a drive than if it has cache.
https://linustechtips.com/topic/1303402-m2-drive-questions/#findComment-14464094
Idk I have been looking at alot of drives I was looking on pcpartpicker for them
Whats your budget? how much capacity do you need?
What board do you have There is no Asus TUF X390-Plus gaming
https://linustechtips.com/topic/1303402-m2-drive-questions/#findComment-14464105
60$ is all I'm willing to spend and I would like to go 500Gb but would be fine with less
https://linustechtips.com/topic/1303402-m2-drive-questions/#findComment-14464110
There is but is it currently useful stuff for a given use case?   I suspect it is stuff that WILL BECOME useful or even required for just about everything, but I’m not sure drives available now will even meet those requirements when the time comes.
https://linustechtips.com/topic/1303402-m2-drive-questions/#findComment-14464171
are you talking about the dram cache?
Part of it is there are dramless drives that are faster than some drives than dram. Thats why I say look at more than cache, or any single spec on a drive, as it can vary a lot between drives.
ALso not having dram won't limit you from using some future programs, as the os doesn't know or care about the cache on the drive. Low performance drives might be a issue, but there is much more to performance than the cache used.
https://linustechtips.com/topic/1303402-m2-drive-questions/#findComment-14464248
