What are your temps?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
It's not? 1.97 GHz is higher than 1.8 GHz, which is the base clock for your CPU.
Also, Task Manager is not a reliable tool to check your CPU frequency, use CPU-Z or HWiNFO. And also check your temps, as said above.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
says in task manager your cpu base clock is 1.8, so it's running above that
fun fact: if it's running below base, task manager will report it as below 100% usage even thought it's 100%
ie, if your CPU is 3.0ghz base, but it's running all core 2.7ghz, it'll show 90% usage
-sigh- feeling like I'm being too negative lately
i did not get it can you make it more clear
it is giving 2 base clocks 1.8 ghz and 1.9ghz which one is the truth
The one that official page says: https://ark.intel.com/content/www/us/en/ark/products/149091/intel-core-i7-8565u-processor-8m-cache-up-to-4-60-ghz.html
says 1.8GHz, that's your base clock, any speed above that is boost clock
Just now, jj9987 said:
oh ok but my laptops screen had broken before that it was running 2.7ghz in cinebech but after it came back from hp i saw it was down to 1.97 ghz any idea
2 minutes ago, Mohammad Saleh said:
single core: 3.7 to 4.3 ghz  and it is plugged in
then it's working just fine, what seems to be the issue?
the all core boost it went from 2.7 ghz before repair to 1.97ghz after it
i see, but as of now it's still running as spec-ed so i cant really tell you what's wrong with it
check temps with hwinfo64, see if it's overheating just in case they forgot to put on the screws
other than that, no idea, because it's operating as it should
it is the 70 to 75 degrees range and thank you for the help i got the point
definitely normal temp
maybe 2.7ghz was on a different workload, or early on during the start of the boost where the CPU may boost to that speed for few seconds before dropping to lower clocks
There are many factors that influence CPU frequency boosting. While that CPU does have theoretically all-core boost of 4.1 GHz, it can be limited if there is not enough power or the temps are too high to allow higher frequencies. Single-core boost is different from multi-core boost, since the power consumption and temperature are different.
it is not terrmal trolling so it must be power
@Mohammad Saleh Run HWiNFO and find out what throttling flags are being triggered. Most throttling in laptops is power limit related. The 8565U has a 15W TDP rating.
Intel designed this CPU so it will power limit throttle and slow down when fully loaded. There are two separate turbo power limits that control Intel CPUs and different BIOS versions can set these power limits differently. It is possible that when you took your laptop in for service, they decided to do you a favor and updated your computer to the latest BIOS version. If this new BIOS version uses different or lower power limits, your CPU could run significantly slower than it used to run.
Here is an example of a similar 8th Gen U series CPU in a Lenovo C930 with the turbo power limits removed.
It runs fully loaded at full speed without any power limit throttling.
Your 8565U is a faster CPU in theory but it will not run this fast if it is being throttled to the default 15W.
When you run HWiNFO64, choose the Sensors only option and scroll down until you find this information.
You will likely see the reason for throttling as IA:Package Level RAPL/PBM PL1 or PL2/PL3. These are the turbo power limits. I prefer using ThrottleStop because it makes the Limit Reasons data easier to see. Use either program. Best not to use both programs at the same time because HWiNFO can interfere with the Limit Reasons data that other monitoring software tries to collect from the CPU.
ok let me try
