Hi,
I managed to get my hands on a Gigabyte Aorus Master 3070 as I seen one come in stock. I stupidly didn't think about if my CPU would bottleneck this card and now that I've installed it I'm getting less FPS than I got with my 1080ti. I assume the issue is bottlenecking however can anyone confirm this or suggest any other reasons why? I have an i7-6700k.
I am currently debating sending the card back as I am getting drops to below 60fps which is making the games i play feel choppy in comparison to my 1080ti.
Thanks in advance
https://linustechtips.com/topic/1302535-cpu-bottleneck-or-other-issue/
I assume the issue is bottlenecking ....
Can't be bottle-necking. Bottle-necking doesn't work like that. A smaller than expected increase is a bottleneck.
A 1080ti to 3070 bottlenecked scenario would typically yield a 0 - 15% FPS increase not a negative one.
Use MSI afternburner to monitor GPU usage, clock speed and temps as a graph. It might give you some more info.
I wouldn't send it back, they are hard to get right now you got lucky, could be drivers, use ddu to uninstall. and the 6700k is a little bit weak for that gpu, unless you play at 4k, or 1440p ultra maxed settings and are fine with 60 fps. but you can leave them together for now until you can afford something better, the 6700k is no slouch and is fine until you get something else.
Ok i will try that thanks a lot. If all checks out there do you think it could be a defective card?
Just now, Pc6777 said:
I wouldn't send it back, they are hard to get right now you got lucky, could be drivers, use ddu to uninstall. and the 6700k is a little bit weak for that gpu, unless you play at 4k, but you can leave them together for now until you can afford something better, the 6700k is no slouch and is fine until you get something else.
I plugged the pc into my 4k tv and im getting around the same fps im getting between 60 and 75fps on cod warzone with the 3070
No, a defective GPU would show things like, crashing or black screens, artifacts on screen etc.
the 3070 does have less vram, and if you play 4k 60 fps the i7 6700k if fine and you dont need to upgarde the cpu, if you wanted to play at 1080p or 1440p high refresh ate you would need a cpu upgrade, but the 6700k is fine for 60 fps gaming. try some other games to see if its just cod warzone and check vram usage, and use ddu and reinstall drivers and test again
1 minute ago, Pc6777 said:
the 3070 does have less vram, and if you play 4k 60 fps the i7 6700k if fine, if you wanted to play at 1080p or 1440p high refresh ate you would need a cpu upgrade, but the 6700k is fine for 60 fps gaming. try some other games to see if its just cod warzone and check vram usage, and use ddu and reinstall drivers and test again
See i play on 1080p 144hz right now and i planned to stay at 1080p or maybe go up to 1440p. I prefer the smoothness to the higher resolution. Issue is I dont think i can really upgrade my cpu without needing a new motherboard as well so at that point im not sure if its worth the hassle since the 1080ti is still really good. ill try using ddu and reinstall the drivers right now
I have the same cpu as you, but I normally play at 60 or so fps because I use an rtx 2060 at 1440p, if you want 144 hz you need a better cpu, and you will need a motherboard, intel started being dumb and not letting you put server CPUs in desktop motherboards because intel loves putting up invisible walls everywhere. if the new market is bad for cpus right now, you could always get a used motherboard and an older i9 or i7 that has more cores like a 6 or 8 core i7, and reuse your ram. you can probably resell the 1080 ti for a good amount to help offset the cost of the 3070, i would just keep it  because future facing rtx and dlss stuff. I mean the i7 6700k can play easy to run fps games at 144 hz no problem, but hard to run triple a games will run at like 50-75 fps depending on how bad the optimization is.
Ok thanks for the help. I will probably take a few days to decide on what I am going to do. I was planning on building a new pc when i finish uni in a year or twos time which is why am not really liking the idea of buying more parts right now. thanks again for all the help everyone
if you dont want to get a new motherboard/cpu, just play at 4k 60 fps to kill the bottleneck lol, might as well.
Issue is i play a lot of competitive games so high refresh rate really is important to me
ampere does use more cpu for the same fps, so it could be a worse bottleneck than before, but it'd only make sense if your 1080ti was already bottlenecked.
be sure to ddu ur drivers.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
depending on the games you need high fps in the 6700k could hold you off for a little while, look up some benchmarks of the 6700k in the games you need high fps in. you could also overclock to like 4.8 or so ghz to squeeze some extra fps out.
Im reinstalling drivers rn but my 1080ti performed very well it was just starting to show its age a bit on warzone but tbh i think thats just cause that game is an optimized mess
I was thinking of overclocking my cpu however i only have a 650w psu so not sure if that will affect overclocking
