What's CFM, and how is it important in case fans?
Solved by mariushm,
The CFM value will be proportional to the rpm value (how fast it spins) ... a fan may have higher CFM but reaches that amount at higher rpm, meaning it's more noisy.
CF120 is:
FAN Speed | 500~1800 RPM±10% |
Fan Air Flow | 52.5 CFM |
Fan Air Pressure | 2.08 mmAq |
Fan Noise Level |
≤28.8 dB(A) |
MF120 is :
Fan Speed | 500~1800 RPM±10% |
Fan Airflow | 60.6 CFM |
Fan Air Pressure | 1.73 mmAq |
Fan Noise | ≤35 dB(A) |
Fan Speed (with LSP) | 400~1450 RPM±10% |
Fan Airflow (with LSP) | 48.3 CFM |
Fan Air Pressure (with LSP) | 1.1 mmAq |
Fan Noise (with LSP) |
≤29.5 dB(A) |
So the MF120 can push more air, but with much higher noise (35dB vs 28.8dB).. with the noise reduction (basically making it run at 9-10v or something like that), you get less CFM and still higher noise amount.
The MF120 is also less good at air pressure, meaning the amount of air flow will be affected more significantly by obstructions in the air path (if your case has mesh, or a grill with lots of metal through which the fan needs to push air... it won't do well.
