Is it possible to setup a router as repeater without cable
Solved by Naijin,
4 minutes ago, daividg said:Hi I've have just moved in in to a new apartment where the WiFi router is in the owners apartment but the WiFi signal stability is trashy and the speeds are not good either. But setting up a own network is not allowed. Is there a way to setup a WiFi router as WiFi repeater without a Ethernet cable?.
Since there is no network device or cables in your apartment, I assume you don't pay for internet either?
