11 minutes ago, Harry_Barnes said:
Hi guys, recently my pc has been making a weird noise around the cpu, ram, mobo area. The pc runs well at the moment but I was wondering whether I should be concerned
1. specs?
2.describe sound and what fan configuration
https://linustechtips.com/topic/1301332-weird-noise-from-pc/#findComment-14447697
is it continuous? liek a high pitched whine? if so could be coil whine?
not much you can do if it is that
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1301332-weird-noise-from-pc/#findComment-14448202
