Will Corsair LL120 work with the lighting node and fan splitters? Buying 6 and want to know what kind of control I will have?
Solved by minibois,
QuoteWill Corsair LL120 work with the lighting node and fan splitters? Buying 6 and want to know what kind of control I will have?
Yes.
You connect the fans' RGB connectors to the RGB FAN LED HUB and then the Node Pro like this:
and then you connect the PWM cables to the fan splitter and then your motherboard.
