Watercooled GPU for mining - max memory overclock
Solved by tikker,
Yeah core won't affect ETH much. In the end heat is the biggest threat. The unsafe aspect of high memory clocks is the lack of temperature sensors on the memory chips, so it's impossible to judge safe operating ranges. It might be running extremely hot which could damage it over time.
Also when I was reading up on my 1080 Ti I saw it mentioned that GDDR5 and newer have error correction built in which could lead to higher apparent hash rates, but lower effective rates as it has to correct the errors it made due to higher clocks and take longer to finish a share. Can't find it anymore though, so take this with a grain of salt for now. Might be visible if your pool reports your effective hashrate alongside your reported hashrate.
