How to make 5.1 surround sound system wireless
4 minutes ago, LpoolTech said:If only I'm afraid its a lost battle we done a major renovation few years back I wired all the flat with cat6 but did not think about speakers wire, there also isn't a clean way to hide the wires. I can't go in to the walls (brick), we don't have carpets (hardwood floor) and two of the walls I would need to pass along are mostly empty. It's not a big deal in the end, I will have better audio setup in my office
I'm guessing the surrounds are the biggest issue? Are you close to walls? The front and centre cables are easily hidden behind a TV stand. For the surrounds you could perhaps look into cable gutters to run along the floor/corner/ceiling? There's also something called Ghost Wire you could look into (thin and flat cables), but they do seem to require some proprietary stuff to terminate properly.
