Ryzen 5600x - ihs thermal conductivity?
Solved by AngryBeaver,
5 minutes ago, AlexGhe said:For case fans I have as follows:
Front fan: NF-A14 PWM with low noise adaptor
back fan: NF-S12A PWM with low noise adaptor.
The only fan in my case without low noise adaptor is the cpu cooler fan, because at base speed it's completely silent even without the adaptor, being inside the case.
After a little more digging through reviews and benchmarks it looks like your temps are perfectly in line. If you really are concerned you could disable pbo, but then you would be leaving performance on the table.
If I was you I would do thr undervolting tweaks to see if that helps. Chances are your temps and cpu clocks will all see a slight improvement.
