do all case fan are gonna work in a fan hub as long as it has 3/4 pin?
Solved by tkitch,
Okay, so reverse image search found two possibilities for this fan:
https://shopee.ph/YGT-FAN-DOUBLE-RING-LED--DIAMOND-120MM-i.60584520.8002479612
https://www.carousell.ph/p/ygt-dual-ring-diamond-rainbow-ly-1225m12s-dc-12v-0-2a-120mm-1034101656/
So, with that connector (on either) you can't control the fan speed, or RGB. It's going to be Full Speed, and the LEDs will do whatever they're programmed to do.
