MY PC's Evoloution.. From Hacked Together Prebuilt, to a Clean PC
Journetta
It all started Off in a HP Elite 7500 Series MT prebuilt, with an i7 3770, and a chucked in GTX 980
Then some big changes, Corsair 750d Case, New CPU, Ram & MB (i7 6700k, 16gbs 3000mhz ram, Maximus VIII hero)
I Swapped Cases early in 2020, to a Corsair SPEC-06 RGB
I upgraded to a white cooler, to better match the ashetic im going for
Made my GPU vertical mounted!
Then finally , i painted my motherboard and graphics card to white, and it brightened up the build so much better
QcAzUgYwsRn3Jh-r8TM0f8cnFbGqShz_qAV5RRq3MZogfoNWmrfRN3pBY8bFhdel0Jmpu1W-kfHed7Rla2Gdo04t0pDvoz9DDccd7pGEXTq8thtddkRnva4W-uREWVgFZ2WNuUVeiL5HVmaw6KEzMFvvwqQZfVPg7kP2370uDzvXeD_b1p-PDMzcLSostRc2OlQzITBGisM5DWYYF6ezvF8q63o0i6KXGlMgpiUOwpqcRvAOujn72vB7oFqhY_DmtoEgMyfsYHAvHttE-SsXeVa_Bziv8HJUilMzIpAMaGr8bZbjS57bnAES74aU9tQjgV1vkSk0K7zMu-8utMlAVaWHI10XQB1k548fFmaR_aj3SUmsyIV_mLmuxCl3oPoNFR_sGQtkTwaMEhMuiNdm17QdtmPDa6bqDx3Oy_9_ctEnNgKOKwy3-De0pfzrHU-wHNUJFhzhDuBMoNFR7TyJBNbFQS6trnGG3Th4GR0kTBX3w2mdiLA6-ae8EFXWD5UJrES-g8nXRjeIdf3jWNV2Zv8NvPuMiL6hcFrjUeMqDlnkX8IQrz0TlD2SbZJNC738hpa4bOghB0nS7XJ9c1H4dhtCM_isKszQRYnF61ATgMTB4GAqPUzEWdC1idTM7mbW-7phRFIq13bBD4bUPQBeNIQNdKan6IO5N37LCB3WzEzruYfXY8PxX4U1bnE28nI=w1599-h899-no?authuser=0
So basically you've changed everything but not gpu and done some great painting awesome!
It's too bad the last image isn't loading for me, I'm sure it's the coolest
Primary PC:
Basically XD although i did used to have a 750ti? i believe before the 980 so yeah thinking about it i probs have changed everything lool
I mean that's upgrading a pc though.. Just doing it slowly over the years, alot of people keep the same cpu and mobo combo but upgrade the graphics card soo
Edit i think it was actually a Asus 760
See the source image
does this load?
ABSRlIpmQgs8ifI986xqzwGzBpTP3nrKX_imdgvh1JTYQrL_RKpys5dfWUi0Bgsdve7honPvgBspCxgYmbBxZ70a4-O8TNto45kBS2NpAZOKFC8EkqlOzP0x0U8ktoch9spNlNDrtemprBqIT2fKl21c61B6_-IfYlWhVgK4u1Ym_tdAcxre8rTDWQexpnB9G_ny1Bm4Ypp9sdWXcGo-ZbV7lv1xYzIlhlaZZ1Wbmuxa4L_xdA_TJErupWcPgYj8eaSt_6ASDceaSRa08xlSMXT-rxI3XiW3S9PAZ4AL_2vtzXpHHi-mH3eSgVQ2V0PIzbdRokLLZKlS6w3_Kz2ayYEX-gA4Tfs0NvSP1wjGXbE6ajdogtZizJ_MLkDn-mcTzWEmf_siPzffvZ5fgTwMPq4zCVPIN2lV0KxnwqWjsg8wsHq3hk5rqWGFQY8WdMUS0UoCq7jjjveqi_R57ggYFn9Qaxf4pTueSLPy_Rg65rxnZEphF_YCpA7fPIlDJErsVFN0Cf4ogMZXalNBfold5gTzsVgsbVRc25YmykYl5eMo3e2xolgg3Ht6Us7sQbpqG6CkEM77tyQrUyoZ41iTtciVoWQzb8SPAq_92whwX2hQ3AX06-me-1hcXrD74_zuhYhrKvyv7DUtbiC6UbKkZYtY8iFN61Rb24pLyMOP8_C5DM15VuVKxF6S8nQfBmGsWn_GyzAT25-e7exb5SLIqesAKvRVdZA66clVhtXrgZU=s1599-w1599-h899-no?authuser=0
As a fellow PC builder that started out with a prebuilt HP Elite, well done!
I also went with an everything upgrade, first for looks and then for quiet operation.
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
5 hours ago, Journetta said:
does this load?
Not sure what's going on
Primary PC:
me too wont load
