nas case Any suggestions for a smalish case for a silent NAS ?
Solved by Blue4130,
6 minutes ago, LinuxTux23 said:Hey there,
At the moment I build myself a small NAS ( with TrueNAS as OS ). For Mainboard I wanna go with the ASRockRack X570D4U and a Noctua NH-D1.
I really wanna have a case with hot swap bays, for easy drive replacement. One of the most convincing cases i found was the CS380 from Silverstone.
Does anyone out there have some suggestions for a smallish NAS / Server case ?
Or is there a possibility to build hot swap bays in a kinda standart case ?
Thanks !
Unless you are buying for looks, don't worry too much about hot swap bays. Think realistically, how often do you expect drives to fail? Once every 5 years?
