new build works but wont post on screen
Solved by somer4ndo,
I agree with Biomecanoid on both points, "help" is not an acceptable tittle. To fix this you'll need to clear CMOS, the most standard way is taking out the battery in the motherboard(with the PC turned off and disconnected from power) and leaving it like that for a little while, for easier/faster method of doing this, we would need to know which motherboard you have.
