Getting directional sound to work?
Statik
Hey all,
I have Sennheiser HD598s, and haven't had issues with them for the years since I bought them. I just plugged them into my setup for the first time in  ~7 months, and have Stereo selected, but I can't get directional sound to work (E.G. when I play a sound in the left speaker, it comes though both equally). Any ideas getting this to work? I dont know what the issue is
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
11 minutes ago, Statik said:
Hey all,
Have you tried checking if it's not program's fault? Or did you try playing a directional sound from site like YouTube/etc.?
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
I've tried both sounds on youtube, and in apps. It doens't seem to be set right when I click to play left ear, versus right ear/both.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
Do you use a program that alters sound to make it more surround for example for games?
PC:
PCs I used before:
I figured it out...
My headphones were only plugged in 95%. I'm officially an idiot.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
14 minutes ago, Statik said:
I figured it out...
Lol well good for you that it's not a broken software or hardware, 🙂
Btw may I ask how much fps you get on your cool lookin' pc?
PC:
PCs I used before:
I mean depends on the game, and I just got back to using it after being gone for a while. So all I've played is Escape from Tarkov, and I usually get around 90-100fps on 3440x1440p.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
cool (I have 64Hz monitor so that would be more than enough for me 😄 )
PC:
PCs I used before:
2 hours ago, Statik said:
I figured it out...
I read the first post and said out loud I bet there not plugged in.
