I want to build a (Mid-range) gaming PC, and I am having a tough time choosing a case.
Things I'm looking for
Good ascetics
Modern design
good IO
Tempered glass side panel
UNDER 80$
Things I'm not looking for
RGB Fans (Over the top RGB in general)
USB-C is not something I use.
Not large (You make what you think of that)
I've looked at a few and am turning to the LTT community for some help.
Do mind this PC is not going to be build until Summer 2021
Things I have looked at
NZXT h510
Darkflash DLM 21/22
Corsiar 275R airflow
I know the NZXT case has bad airflow, but you can look at the parts list below and see if you think airflow will be an issue. I have chosen to have Noctua P12 Redux 120 mm fans for the case so if the case has fans I most likely won't use them.
Parts list below
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1296660-case-for-my-pc-build/
first of all the noctua redux are pretty bad value. there are Artic P12's that are same performance for 50% of ther price.
Second the corsair airflow is much better. I would not get any NZXT H500 lineup cases.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412457
Just now, yaboistar said:
meshify mini c comes to mind if you can find it for the right price
Yea I looked at that case but it was out of budget rn. If it comes into my price range I will considor it.
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412458
Thermaltake V200
what I used for my pc build, great quality for its price plus it has all the requirements you’ve listed, the rgb on the fans can be turned off if you want.
PCPartPicker Part List: https://pcpartpicker.com/list/qJB4Xv
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($269.00 @ Amazon)
CPU Cooler: MSI MAG CORE LIQUID 240R 78.73 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($394.98 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3000 CL15 Memory  ($174.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card  ($869.99 @ Staples)
Case: Thermaltake V200 RGB ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Asus 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($229.64)
Total: $2338.54
Generated by PCPartPicker 2020-12-08 10:04 EST-0500
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412467
The Artic P12's are the same price on pcpartpicker
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412469
2 minutes ago, Yo soy Jack said:
Thermaltake V200
Yea but the V200 has those punchout PCie covers
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412479
Yeah it wasn’t really a problem for me because I knew what they were but I’ve seen reviews were people have bent the hell out the back of their case getting them out, really the only downside I see
Total: $2338.54
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412484
I'm thinking I'm going to go with the Darkflash DLM 21 (Mesh version) because it has good airflow and all the features of the V200 at almost half the price.
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412499
Good choice, I mostly chose the v200 because there’s a cutout for the PSU and the one I bought has an OLED screen
Total: $2338.54
https://linustechtips.com/topic/1296660-case-for-my-pc-build/#findComment-14412505
