AIO Aorus 240 whirring noise
Solved by Quackers101,
8 minutes ago, Betaraptor01 said:I'm quite sure it's not coil whine or bubbles, the noise is quite deep and vibrating, literally like a small motor. Also I'm sure it's coming from the block, not fans.
Could be a problem with it, inside and might be nice to return it for a new one.
Like if this is something of a problem of the internals and if this might be a common issue for those AIO's?
At least, if you can get sent back a new one?
