Second monitor help
Solved by trag1c,
17 minutes ago, Mdog504 said:Would an rtx 3070 support 2 1440p 165 hz monitors? And still be able to ray trace. If not would a 1080p 60hz monitor work?
If you're just looking for the 2nd monitor just have stuff on it while you game on the other it will have zero (or nearly absolute zero) performance penalty. I have 1 1440p 144Hz monitor and 2 1440p 60Hz monitors that are all 27 inch on my desk right now. There is no performance impact at all and currently I am running a GTX 1080 so its a fair bit slower than a 3070, but no issues at all.
The only time that you might run into problems is when you have limited VRAM either from a card with not a lot VRAM to begin with or your taking one out of LTT's page and running 16 4k monitors.
