Wordpress Theme Lensa help
Solved by Sidewinder,
now the first picture is only white. Even if I change the picture it's still white
Right, I see it. Remove the CSS from before, try this instead
.supersized-pattern { visibility: hidden;}
Does that work?
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
