Budget (including currency): 1990-1950 usd with tax
Country: United States of America
Games, programs or workloads that it will be used for: Everything Gaming at 1440p as well as just general use and maybe not intensive productivity.
Just another post asking for feedback on the build they put together. This one is mine. Just before reviewing, keep in mind this is build is primarily meant for gaming and general use. I plan to add another 1tb sata and 16gb of the same ram kit down the road if I end up needing it. This is just meant to be the version to get the system up and running with good performance. The monitor I have and plan to pair with the build is Samsung G7 odyssey, if that provides any valuable info.  Any feedback is appreciated!
https://linustechtips.com/topic/1292016-feedback-on-pc-parts-list/
Looks great
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
  • I'd probably get a cheaper SSD, there are others that have similar performance for less.
  • That cooler is awful. I'd upgrade to something better.
Other than that it looks pretty good.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Welcome to the forum...
You could have easily saved $500...
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($299.00)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard ($139.99 @ B&H)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory ($74.99 @ B&H)
Storage: PNY XLR8 CS3030 1 TB M.2-2280 NVME Solid State Drive ($114.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card ($699.00)
Case: Fractal Design Meshify C ATX Mid Tower Case ($99.98 @ Newegg)
Power Supply: NZXT C 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ NZXT)
Total: $1557.94
Generated by PCPartPicker 2021-01-10 09:39 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $1557.94
I appreciate you giving feedback to my list. However, on the revised one you posted, you left out about 300 dollars worth of parts and tax (Cooler, Case Fans, and HDD plus taxes of all the parts.) You have saved me around 70ish dollars though (when tax and all the parts are accounted for) and I will look into possibly exchanging my parts for those you previously mentioned.
Do you have any cooler or ssd recommendations? In addition, I went with that cooler on my list because of some people recommending it to me. I thought it would be fine cooling a 5600x with pbo enabled, but if not, I would happily exchange for a different one.
27 minutes ago, Mousse said:
Thanks for the feedback! Unrelated, but do you actually have the PC of which your specs list reads?
yes
SPEC LIST:
  • Case: NZXT H710
Skip the cooler as 5600x already comes with one.
Look for cheap argb fans from brands like Asia horse, they are pretty cheap and look good.
Yeah, I skipped the HDD. You can add it if it is required.
You can get all this for around $100.
SSD TIER LIST
CPU - Ryzen 7 3700X
