Not sure how to set up the Corsair RGN fan hub
1 minute ago, LewisBros said:Ah, okay this makes sense. I wasn't aware that I needed another device to plug it into. In that case which one should I purchase?
Corsair LED fans have two wires on them. An RGB wire and a PWM wire.
The RGB wire is purely for the RGB, while the PWM wire is for speed control of the fan.
If you need to get the Commander Pro or Node Pro, depends on where you plan to plug in the PWM wire.
The Node Pro only does RGB, while the Commander Pro does PWM fan control too.
The way you plug them in would be like so:
Node Pro:
Commander Pro:
(note the difference is the green wires, which is for PWM control).
Source for the pictures:
https://forum.corsair.com/v3/showthread.php?t=173880
Keep in mind you can't mix Corsair LED fans on one hub. Can't combine LL, SP, HD, etc. fans on one hub.
