so i reently put a ryzan 7 in my system the stock cooler was mostly DOA the leds were the only thing that worked i had an old cooller that was used to cool a ryzan 3. my ideal temps right now are around 40-50 is that to high? could tuing off core boost lower it?  do i need. a difernt coller (i dont want to spend anymore money)
thanks yall
https://linustechtips.com/topic/1289586-cooling/
thanks yall
40-50 C idle temps are actually pretty good! As long as load temps don't go over 80C I'd say you're good to go!
Also, welcome to the forums!
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1289586-cooling/#findComment-14360369
Your CPU temp will only become critical once it exceeds 90°C for longer periods of time. 45-50°C is standard for idle. You have to look out for load temps.
Also remember to quote people so we can see you replied.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1289586-cooling/#findComment-14360375
Just now, Stahlmann said:
Your CPU temp will only become critical once it exceeds 90°C for longer periods of time. 45-50°C is outright freezing for CPU standards.
in that case i wish my room was a cpu (The joke is my room is frezzing cold)
https://linustechtips.com/topic/1289586-cooling/#findComment-14360383
1 minute ago, wtone22 said:
thank you and thank you
I edited my post. Please reload the page again.
I didn't realize your temps were idle.
https://linustechtips.com/topic/1289586-cooling/#findComment-14360384
