4 minutes ago, Flexhaler said:
Newest/ low cost Graphics
Very bad time to be buying a video card, prices are hyper inflated due to shoretages.
Intel Core 2 quad Q8300
GTA5
Is this CPU even on the minimum system requirements list for GTA5?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
For an old system like that, a used GTX 750 or 750 ti is the best I could recommend. You really don't want to be investing any money in a system like that but if you must, you can spend less than $50 on a low end card.
I use my 750 ti to play on 1080p low and GTA works fine, though I do have a generation newer advantage in my rig.
Primary PC:
PSU tier list
How many watts do I need?
A used GTX 750/750Ti should be a good fit.
It might not be worth going for something too much faster than that, since your CPU might hold it back depending on what you're doing, and I also wouldn't get anything that requires external power (for instance the 750Ti only draws power from the PCIe slot) if the PSU is as old as your other components.
Spending 15 seconds doing a Google search on that would answer your question.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
It would have, but the OP could have also listed his full system specs about what he's currently working with, so we don't have to play 20 questions trying to find out what he';s got already (you know, RAM, existing GFX card, OS...for all we know he's got 512MB of RAM, Windows 98 and a SiS GFX card, in which case he has much larger issues)
GTX 1050 used or an GTX 1060 used, both will do what you want :D when GTA V is what you want you can get away with an cheaper 3GB GTX1060.
When feeling lucky a n older 780GTX will do it to.
just avoid older AMD Cards.
CPU
Intel  i9 13900k
Motherboard
Asrock Z790 Taichi
RAM
Kingston Fury Beast DDR5 RGB 32GB 6000MHZ
GPU
MSI GeForce RTX 4090 GAMING TRIO 24G
Storage
Samsung SSD 980 PRO 1TB
Unraid NAS 10Gbit about 50TB HDD's, i713700k 64GB DDR5 crucial @ 5800Mhz
Win11 Workstation
