-= Topic moved to New Builds and Planning =-
@MartinF513Welcome to the forum! Please be sure to review our forum rules when you have chance.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1288947-help-pls/#findComment-14355402
I was GPU shopping a few months ago and found that the best bang for the buck was a 1070 or 1070ti I went for the 1070 which I bought $180 used and ended up being pretty nice.
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
https://linustechtips.com/topic/1288947-help-pls/#findComment-14355414
my pc is a hp Z420 pre-built that i bought for cheap considering that i live in egypt
Specs:
Cpu: intel Xeon e5 1650
Gpu: Nvidia GTX 1050 ti 4Gb
Ram: 8Gb 1333mhz 4 sticks (going to upgrade to 16gbs soon)
MB: i honestly don't know
Psu: original 600w 90+ psu from HP
Note: there is 2 6Pin connentors in the Psu currently using only 1 of them
https://linustechtips.com/topic/1288947-help-pls/#findComment-14361103
It seem like this machine comes with a LGA2011 motherboard with a C602 chipset, meaning the CPU upgrade options are a bit limited.
I feel like the most useful upgrade right now would be a better processor (along with more/faster RAM), although saving up and upgrading both your mobo and CPU to something more modern seems like an even better idea.
Ryzen 5 3600 | RTX 3060Ti | 16GB RAM | X570-A Pro
https://linustechtips.com/topic/1288947-help-pls/#findComment-14361665
Ya well i know but next year i'll save up and buy some mb and cpu and ram bundle
So what now?
https://linustechtips.com/topic/1288947-help-pls/#findComment-14362855
So what now?
If you really want to get a CPU upgrade in the meantime you can check out the list of compatible one's on PC Part Picker and try to buy one with more cores or higher clocks.
Put a "Supermicro X9SRA" on the motherboard slot and browse CPUs with the compatibility filter on.
https://linustechtips.com/topic/1288947-help-pls/#findComment-14363328
ok but what about what the Gpu upgrade???
https://linustechtips.com/topic/1288947-help-pls/#findComment-14363462
On 1/5/2021 at 7:40 PM, MartinF513 said:
Hmm ok but how big of a bottleneck will it be tho?
It's not possible to really calculate that but you can watch this video to get a notion of how it works and what different levels of bottlenecking look like.
https://linustechtips.com/topic/1288947-help-pls/#findComment-14368975
I watched it. But what do u recommend for a gpu upgrade?
https://linustechtips.com/topic/1288947-help-pls/#findComment-14374915
2 minutes ago, MartinF513 said:
Bro?
I kind of think your best bang for the buck upgrade would be CPU over GPU.
When you're using your pc as you normally would, is your CPU or GPU the one at 100% usage?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1288947-help-pls/#findComment-14398666
Hi everyone.
Found this topic with similar problem that I have.
Buy now, or wait for price drop to buy more powerful setup.
I have now:
Intel i7-3770
Asus P8Z77-V LX
Corsair Vengeance 16 GB DDR3 RAM
Asus ROG Strix GTX 1080 Ti
I can get for 770 USD:
AMD Ryzen 9 3900XT (pre-owned)
Gigabyte Aorus B550 Pro (brand new)
G.Skill RipJaws V Series 16 Gb 3600 Mhz RAM (pre-owned)
Obviously GPU will migrate to newer system.
Any advice what must I do?
https://linustechtips.com/topic/1288947-help-pls/#findComment-14399958
bro i entered a giveaway for a rtx 2080 super i really hope that i win (praying for it)
if i win it i will buy a r5 5600x and any b550 mb and 16 gb and an rtx 3050ti if budget allows it
Aaaaand i lost
I hate my life
https://linustechtips.com/topic/1288947-help-pls/#findComment-14423028
