Help formatting 'write protected' SD card
Solved by AbydosOne,
5 minutes ago, ragnarok0273 said:Guess Nissan flipped it.
On the 16GB SDHC card I got from a Nissan Leaf (got it used and the stuff was wiped, but we got the card, now in my Wii for homebrew) it's the other way around.
To remove ambiguity:
(but like I said, it really depends on whether the reader cares, not necessarily where the switch is placed)
