New ultrawide monitor for rtx 3080
3 hours ago, migeo said:My local Canada Computers had the CRG9 on display and I was able to see how big it is before the lockdown and I know now that I have enough space. That's why I'm even considering such large monitors.
I've never used G-Sync before but I thought since monitors are investments, you get them and they'll last longer than your PC (my current one lasted for 3 whole PC builds), I thought I might as well go more high-end and futureproof as much as possible which is why I thought of g-sync and HDR
I have a 3080 though, so isn't it locked to G-Sync? I know there are some Freesync monitors for which adaptive sync works with Nvidia GPUs but I read that most of the times you lose some features such as for example, lower max refresh rate. But I have included g-sync compatible (freesync) monitors now in my search (found them through pcpartpicker) but none of them were available at CanadaComputers
Ask anybody from Canada, CanadaComputers is not particularly great, but they are the largest chain which is why people keep on going to them. All backorders have to be ordered in store and I can't seem to enter gift cards paayment method. I read in one of their pages that you enter your gift card number the same place where you enter coupons but even then, it didn't accept it and I wasn't able to redeem it.
So far I've found these two additional monitors:
https://www.canadacomputers.com/product_info.php?cPath=22_700_1429&item_id=094479(^ newer variant of the one below AFAIK v)
https://www.canadacomputers.com/product_info.php?cPath=22_700_1429&item_id=139017
I'm leaving for Ottawa in a few minutes since the closest store that's open right now is 2 hours away. Hopefully during these 2 hours, I'd get a new reply, hopefully helping me decide on which monitor to order!
The Gsync comment was directed at someone else.
No, you can use FreeSync as well. The newer versions are a lot better though. It's not as good, but opens up a lot more options.
I am from Canada, I've never had to shop at Canada Computers. Did you try calling to see if you can get them to work that way?
For the difference in price I'd just go with one of the Samsungs.
