Best Thermal Paste?
Solved by Tan3l6,
Kryonaut is top of the line. The temperature difference between similar products is quite low.
4 minutes ago, RokenPrice said:When my previous MB died and I had to replace, I got liquid metal. Haven't looked back, and much easier to apply than paste.
You did clean the surfaces and spread the liquid metal with a cotton swab or something and did not worry that the liquid metal is electrically very conductive?
Liquid metal belongs under CPU with easily removable IHS-s.
Correctly applying liquid metal is much more difficult. With paste it's just a ricegrain sized portion in the middle of the IHS and ready to go.
