Will this AIO fit with mobo and case?
Solved by Applefreak,
16 minutes ago, afaq0 said:
The AIO is 52 mm thick. You need at least that in clearance to mount the radiator. Of course you can get aftermarket 15 mm fans, then you will only need 42 mm of clearance. However this will set you back another 30.- or 40.- plus shipping.
Now this only applies if you were to mount the AIO's radiator up top. If you were to mount it up front, you have ample clearance and no issue what so ever.
