Hey guys i recently bought a tuf 3080 and noticed that it's sagging, i know it's bad (although i dont know exactly why) but i dont have a gpu bracket rn so i thought of folding a paper combined with a charging brick to put at the end of the gpu to prevent sagging.
is a charging brick as an anti sag bad and should I look for other stuff to use? or i can use this for the meantime. here's a pic of it
https://linustechtips.com/topic/1283837-gpu-sag-solutions/
If you have some spare LEGOS laying around...build a column to support the end of the graphics card. Otherwise, there are third party products that support the GPU.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320709
I came to suggest this.
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320714
unfortunately i dont have any legos around and im planning to buy a bracket soon, is this fine as a placeholder gpu bracket? will the charging brick cause any issue or will it be fine?
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320716
Btw your ram is in the wrong slots
Just get a cheap pillar style bracket
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320719
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320722
No you'll be fine using the charging brick around (other than not using it for charging haha). It'll be fine until you get the bracket. Just make sure you remove the charging brick IF you are moving the PC around to prevent having a mass being knocked around in the case during transport.
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320723
Cool! thank you for this! ill be sticking with this charging brick untill im able to get a bracket. BTW what gpu bracket can u recommend to buy, a vertical one or an L one and can you name a brand or link an item if you have a suggestion? thank you!
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320735
images?q=tbn:ANd9GcQMbYYjUyWeh8w_kqZKeDaCg1Gk4ZA4G45IcKJOtTQSc6vSmhyPWk-zLaVL-w&usqp=CAcI suggest getiing something like this for such a large card
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320742
2 minutes ago, The-One-Polish-Guy said:
Not the greatest idea to do, i would just get something cheaper that works fine
wdym get something cheaper? like another motherboard? lol
im thinking of that one too i found one on amazon it's called "UPHERE" brand idk if it's good or will it even fit in my case
https://linustechtips.com/topic/1283837-gpu-sag-solutions/#findComment-14320746
