10850k thermal Issues. Help!
Go to solution Solved by xg32,
5 minutes ago, Coziestman said:
So i just built a new pc recently, and decided to go with a i9 10850k for all my editing and gaming needs (and of course, it was in stock). So to cool this beast I am using MSI coreliquid 240mm AIO.(seems adequate, right???). Along with this my airflow situation is 3x120mm noctua 1500 pwm in the front of my Meshify C (intake), msi coreliquid 240mm (top of case for exhaust) and a fractal 120mm in the back as exhaust. During cinebench r23 I immediately see my temps shoot up to 86 C (also the highest temp ive seen so far) is this normal? Also, will a dark rock pro 4 or nh-d15 give me lower temps??
Side note: Ill put this chip to 5 ghz and when running cinebench it will immiediately hit 100 C +.
Can someone help me with this?
Full Specs:
Intel i9 10850k no OC
32 gb 3600 mhz lpx corsair - quad channel
ASUS prime z490-a
MSI gaming z rtx 2070
MSI coreliquid 240 AIO used as exhaust
3x120mm noctua redux 1500pwm intake
1x120mm fractal exhaust
Fractal Design Meshify C
Cooler master 850 w gold
a 10850k requires a  280/360mm aio, just downvolt it and forget the last 100mhz, or change cooler.
Full Specs:
ASUS prime z490-a
https://linustechtips.com/topic/1282073-10850k-thermal-issues-help/
Yeah a 240mm AIO Like that is not enough for your CPU if you are choosing to overclock  it like that. Overclocked that CPU is going to bring most coolers to their limits. Id suggest you go with a 360mm Arctic Freezer II. NH D15 will give a bit worse temps then the 360 Arctic cooler, but depending on your fan curves, Would be about the same audibley.
Full Specs:
ASUS prime z490-a
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
since im going to upgrade would I be better off putting the arctic 360 aio as intake and my noctuas as exhaust?
I always do a positive pressure system, so i do intakes for front and top fans, and exhaust the back fan.
Are you aware you won't have room for HDD's? only SSD.
