Help replacing my CPU cooling
Hi all,
I used to have a Corsair H75 AiO, but I noticed it made some weird noises. I swapped it out for the stock cooler of the R5 3600 for now, but I think I will buy a new air cooler.
I was looking at the Scythe Mugen 5 which is very good apparently, however I would really like the top to be black. There is an RGB version which has the black top, so I was thinking I can just order that one and replace the single RGB fan for two of the fans that were included with the H75.
Now the question is, will this perform about equal to a standard Scythe Mugen 5. I understand that this is difficult to answer, but what I really want to know is whether the Mugen 5 is good because of the heatsink, or is it only good because of the included fans. If it's the latter, swapping out the fans won't do me much good.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/1281430-help-replacing-my-cpu-cooling/
Yes should be better than H75, and yes you can use the Corsair fan.
Be advised, check case compability:
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
The Mugen 5 RGB has a good heatsink and the included fan is okay. The H75 fans might not be as quiet but the two combined probably perform better.
What case and ram are you using? Where are you shopping / located?
I have a FD meshify C and g.skill ripjaws V memory. I'm thinking I'll just buy a dark rock 4 Pro or alternatively a arctic freezer 34 duo black/white. I saw that the fans extrude beyond the heatsink on the mugen 5, I don't like how that looks tbh.
My System:
I'm shopping in the Netherlands.
My System:
Depending on how black you want the cooler, good options include:
Phantom: https://tweakers.net/pricewatch/887311/gelid-solutions-phantom.html
Gammaxx GTE V2: https://tweakers.net/pricewatch/1596214/deepcool-gammaxx-gte-v2-zwart.html
Good options, especially the Phantom. Not sure how much I want to spend yet, but if I'm going for a budget option that'll certainly be in my shortlist. Thanks.
My System:
