14 minutes ago, patken007 said:
AMD Ryzen 9 5059x
PC case = DARK BASE PRO 900 | Orange rev. 2
I don’t care about RGB, all i care about is the most efficient and reliable AIO cooler on the market. Price isn’t a problem.
Ek aio, Artic freezer II, corsair capellix
try to get 360/420mm aio on the top.
also get 1x 140mm fan on the front for extra intake.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14295400
Ek aio
Arctic liquid freezer II
( you'll want to check revision to ensure you get the right mounting hardware that will fit motherboard. Skip rev1 get rev 2 or 3 depending on your motherboard.)
alphacool eisbaer
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14296918
I use a evga clc 360mm aio and it kept my i7 10700k @5.2ghz under 70c while gaming for hours on end no problem. I highly recommend this cooler
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14297570
46 minutes ago, patken007 said:
Whats the main difference between rev 1 2 or 3 and how do i found out if i bought the good one.
2 is an upgrade to 1 mostly dealing with fan operation and a couple other minor things. 3 is a change to the mounting hardware to make it more compatible with more amd motherboards. However motherboards with vrm close to the cpu or m.2 close to cpu may interfere with mounting hardware of the rev 3.
If you end up with rev 3 dont worry about it. You can request the mounting hardware for rev 2 if needed to fit for your motherboard from arctic.
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14298385
On 12/12/2020 at 4:48 PM, patken007 said:
AMD Ryzen 9 5059x
280 mm
NZXT Kraken Z63 280mm
NZXT Kraken X62 AM4
Corsair Hydro Series H115i Pro RGB XT 280mm
360 mm
NZXT Kraken X72
Corsair Hydro X (XC7 RGB + XR7 360mm)
Asus RoG Ryujin Performance 360mm
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14300595
On 12/12/2020 at 7:48 AM, patken007 said:
AMD Ryzen 9 5059x
The CORSAIR H150i Elite Capellix would be a good option.  You can choose to turn off the RGB lighting, just set everything to black in the iCUE software.  It also comes with a 5 year warranty, should anything happen, we can have it replaced for you.  Let me know if you have any questions.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
https://linustechtips.com/topic/1280253-best-aio-cooler/#findComment-14303056
