Hi, i just started playing cyberpunk. i updated the driver with a clean installation. then i went to the game and put on rtx ultra and dlss auto, it's supposed to run at at least 60 fps, but my gpu only used 60% resulting a 45-55 fps range. im using 3070 x trio and r5 3600. is there any hidden setting that i don't know that can change or improve this? thanks
https://linustechtips.com/topic/1279362-3070-usage-not-maximized/
Turn the settings up. Playing at low/medium will result cpu bottleneck. High/ultra shoudl be fine.
Also what ram config you have?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
8 minutes ago, dijoliin said:
16GB 3000Mhz
1 or 2 sticks?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
everything is already at max, why is it just using 60% while preforming at 45 fps is the thing that confuses me
Are you running the latest Game Ready driver from Nvidia?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
3 hours ago, IWolfieI said:
A few people on the Cyberpunk reddit found uninstalling the driver(even if you have 460.79) with DDU and then installing the driver fixed it, it took a couple attempts for some. Also remember to restart your system after you install the driver.
this somewhat helped but it is still going for usage of 60% at populated areas making 45-55 ish fps
