NZXT Kraken X60/ H110 or custom loop...
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700483
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700510
this
spend that money on a decent CPU instead.
Error: 410
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700516
Retail i go to frys electronics
[Averykindguy241]
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700630
I'm just saying your buying a cooler worth more then your cpu, doesnt make sense
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700791
Im not
How much are you spending then? Give us a budget? You said best cpu cooler, the higher end coolers are worth more then a 6300...
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1700916
You've opened a few threads like these and not provided us with any information that we need to give you an accurate and worthwhile answer.
But for a FX6300 it makes no sense to spend over 50% of the cost of the CPU on a cooler so grab a 212 EVO.
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1702525
What about for intel i5 4670k wich cooler is good for that one
[Averykindguy241]
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1704717
Again. You've not told us what board, what budget, what the rest of the system is or anything so I can't give an answer.
212 EVO again probably.
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1704943
THIS
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1705045
Center
**Case** | [Corsair Graphite Series 230T Black ATX Mid Tower Case](http://pcpartpicker.com/part/corsair-case-cc9011042ww) | $77.99 @ Newegg
**Power Supply** | [Corsair Builder 500W 80+ Bronze Certified ATX Power Supply](http://pcpartpicker.com/part/corsair-power-supply-cx500) | $44.99 @ Micro Center
| | **Total**
| Prices include shipping, taxes, and discounts when available. | $829.92
| Generated by PCPartPicker 2014-03-16 14:08 EDT-0400 |
[Averykindguy241]
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1705210
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.00 @ Amazon)
Motherboard: MSI Z87 MPOWER Max ATX LGA1150 Motherboard ($212.98 @ SuperBiiz)
Memory: Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory ($79.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: Asus GeForce GTX 650 Ti 2GB Video Card ($139.99 @ Micro Center)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case ($77.99 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply ($44.99 @ Micro Center)
Total: $829.92
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-16 15:50 EDT-0400)
[Averykindguy241]
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1705222
Total: $829.92
Are you open to suggestions on your actual build as it doesn't seem very balanced or thought out (it is a gaming PC right?)
I assume you intend to spend around $800 on the rig based on previous posts.
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($109.99 @ Amazon)
Motherboard:  ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard  ($79.99 @ Newegg)
Memory:  Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage:  Crucial M500 120GB 2.5" Solid State Disk  ($69.99 @ Amazon)
Video Card:  Asus GeForce GTX 770 2GB Video Card  ($328.98 @ SuperBiiz)
Total: $826.89
(Generated by PCPartPicker 2014-03-17 12:06 EDT-0400)
You'll need to remove drive cage to accomodate the 770. Just ghetto mount your SSD with velcro and screw drive in near optical bay (it is doable).
That offers a much better value as a gaming PC as that 650ti is silly in a i5 system and spending $200 motherboard on what is a fairly low cost rig is insane.
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1709524
Case:  NZXT Source 210 (White) ATX Mid Tower Case  ($37.99 @ Newegg)
Total: $824.89
(Generated by PCPartPicker 2014-03-17 12:02 EDT-0400)
thats is alot better performer
My Setup :P
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1709547
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($57.98 @ OutletPC)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case ($39.99 @ Newegg)
Total: $826.89
How about this ?
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($189.99 @ Micro Center)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler ($49.99 @ NCIX US)
Motherboard: MSI Z87-G45 Gaming ATX LGA1150 Motherboard ($129.99 @ Newegg)
Memory: Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory ($81.99 @ Newegg)
Storage: Intel 530 Series 120GB 2.5" Solid State Disk ($89.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($64.99 @ Newegg)
Video Card: Asus Radeon R9 270X 2GB Video Card ($245.66 @ Newegg)
Case: Corsair Graphite Series 230T Orange ATX Mid Tower Case ($69.99 @ Amazon)
Total: $952.58
(Generated by PCPartPicker 2014-03-18 00:50 EDT-0400)
[Averykindguy241]
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1713124
How about this ?
Total: $952.58
Nope. More expensive and worse Graphics, wouldn't really make sense.
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1713458
Do you actually intend on doing any overclocking? Because If not the stock cooler is fine.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/127898-cpu-cooler/#findComment-1713502
