How to boost volume further on Astro's A10?
centurion_08
Hello,
I'll make it short. I'm using Astro's A10 with my PC and PS4. Great headphones but max volume is kinda low. What can i do to boost it, when connected to pc and dualshock 4?
I'm not an audio guy and question may sound dumb but i need advice regardless.
Kind regards.
assuming its a normal headphone jack and not USB you could get a small amp for your PC, be careful though as you don't want to over power them. as for the PS4 controller, unless you can find an amp that plugs in  via headphone jack and runs off a battery (all of which are usually terrible and bulky) you dont have any good way to amplify ps4 controller volume.
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
