Thermal paste replacement safe?
in Graphics Cards
Unless you want a overheating graphics card before failure, it is most definitely safe. Be careful of the any thermal paste that spills over on the edges as there are capacitors/SMD that are located around the edge of the GPU die on its substrate. Just a pea size amount of a thin spread of quality thermal paste will be good.
_Darasuum_ ·
Posted in Power Supplies0 -
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3
play_circle_filled
Latest From ShortCircuit:
