Warzone Problem (CPU 99%) w/ 3070
Hello, im having a strange proble, so i bought a new graphic card (msi 3070 gaming x trio 8gb), my cpu always 99% usage and my gpu 50-60%,  and the funny part is if i play high setting or low settings the fps will be the same
my cpu is running 4.6ghz, any ADVICE?
my spec are:
CPU: Intel Core i5-9600k
GPU: MSI RTX 3070 GAMING X TRIO 8 GB
RAM: 32 GB
Monitor: Asus VG248 TN 24'' 144hz 1080p
Power Supply: Corsair RM750x (2018) Full Modular
Case: Phateks 400s Red/Black
Motherboard: ATX MSI MPG Z390 Gaming Edge AC
Cooler: Water Cooler Kraken x62
https://linustechtips.com/topic/1276744-warzone-problem-cpu-99-w-3070/
Higher res, better cpu, thats all you could do. That is a big cpu bottleneck. Lower settings just gives the cpu more frames it cant process. If you could, I would play at 1440p downscaled to 1080p
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Just now, Abyssal Radon said:
There's your problem. 3070 at 1080p resolution, upscale the game, problem solved.
downscaling from 1440p would reduce the frame rate. Upscaling from lower would make it worse. (he has a 1080p 144hz monitor)
Bios database
prior build:
